WD gear shift transmission problem
nycarl
05-13-2005 18:28:50
I just got our WD out for the first time this spring. The tractor had been sitting since last fall and only used for occasional snow plowing in first or second gear. I had not used third or fourth gear since last fall. I was having some trouble shifting gears but no grinding or loud noises.
I started disking in second gear and after a couple of passes the tractor suddenly stalled. That�s when my problems started. I apologize for the long post but maybe it will help someone diagnose what�s wrong.
You can move the shift lever with some difficulty to the different gear positions with the foot clutch disengaged. However, in first, second, fourth, and reverse when you engage the foot clutch and hand clutch the tractor doesn�t move at all and just stalls out. Neutral and third are the only positions when the tractor will move and then it seems to be in fourth gear.
I took the cover off the hand (transmission) clutch compartment. With the shift lever in neutral, when the hand clutch is disengaged and the foot clutch also disengaged I can turn the shaft by hand. However still in neutral, when the hand clutch is engaged and the foot clutch disengaged you can�t turn the shaft.
The PTO seems to be working o.k. There seems to be plenty of oil in the hand clutch compartment but I have no idea how much oil is in the transmission case. I�ve read about these tractors sometimes shifting into two gears at once. I need some advise before proceeding, especially since I�m not the greatest mechanic.
Thanks
Carl
Texas Denny
05-14-2005 21:15:10
 Re: WD gear shift transmission problem in reply to nycarl, 05-13-2005 18:28:50
If you pull off the shift tower, you can check the forks and the gears and see that they are lubricated properly. It may be that the countershaft is frozen or that it is in a gear and won't come out. When you take off the shift tower, you should be able to shift to each gear and out again with a screw driver if the gears are lined up properly. And when each slider gear is in neutral, they should line up perfectly with the forks when they are in neutral.
However, nothing is obvious to me from your description.
nycarl
05-15-2005 17:27:57
 Re: WD gear shift transmission problem in reply to Texas Denny, 05-14-2005 21:15:10
Thanks Texas Denny. I took off the shift tower and the fork on the center (third and fourth gears) rail was broken off clean at the base. The 3 & 4 sliding gear had slid forward and high gear was engaged. That"s why the tractor kept stalling when I tried other gears. I fished the broken fork out of the bottom of the case. How it didn"t get ground up, I don"t know. Does anyone know whether it could be welded back. I"m no welder. Even if it wasn"t a permanent fix and just kept the sliding gear from engaging in high, I could live with first and second gears for now. I really need to get the tractor working again.
Texas Denny
05-15-2005 20:54:00
 Re: WD gear shift transmission problem in reply to nycarl, 05-15-2005 17:27:57
If it were mine and I was in a bind, I would try welding it for a temporary fix. But a little caution. These forks are probably tempered and a fairly good grade of steel. You could grind a bevel on either side of the brake and do a fillet weld and then grind it down. However, the weld might hurt the temper of the material so the fix should be temporary at best. If you don't get all the dimensions right, You might have trouble shifting.
nycarl
05-17-2005 11:55:27
 Re: WD gear shift transmission problem in reply to Texas Denny, 05-15-2005 20:54:00
Thanks Texas Denny and everyone. I had the fork welded as you described. It's back in the tractor and working so far so good. I going to try avoiding 3rd and 4th where the welded fork is.
