1939 model WC where to buy seal?
old smokey
05-12-2005 11:09:57
i need to buy a front crank seal,where do i find one?any one know how many of these tractors were made?what are the specs on these?hp?what was the pto off the bottom of the trans for?
Doug in IL
05-12-2005 17:13:38
 Re: 1939 model WC where to buy seal? in reply to old smokey, 05-12-2005 11:09:57
The seal should be available from your Agco-Allis dealer. There were about 16000 1939 models produced. About 104000 styled WC's in the total production run. 24.16 drawbar horsepower, 29.93 horsepower on the belt. Maximum drawbar pull of 3136 pounds. The pto you see under the tractor is not complete. There is a shaft that attaches to it that extends to the rear of the tractor and is held up with a bracket with a bearing in it. Mine also uses a different drawbar with the pto shaft. A belly mounted sicklebar mower could be driven by the short shaft coming out of the box. There may have been other attachments that used the short shaft like you have, I'm not sure.
