WC bearing shims
Govn'r
05-11-2005 16:38:34
I while back I asked about the shims on my rod and main caps, as far as actually using the shims. I appreciated the response. One more question. Why do the use the shims? Did they do this new, out of the factory?
Texas Denny
05-11-2005 20:53:04
 Re: WC bearing shims in reply to Govn'r, 05-11-2005 16:38:34
Yes, the shims were used at the factory. Answering why is like mind reading. Since no one reading this was there when the decisions were made, an answer can not be determined. What can be discussed is advantages and disadvantages. An advantage is that the manufacturing tolerance need not be so tight if shims are permitted. If shims are in the rods and mains, at overhaul time the shims can be adjusted for satisfactory performance without replacement - at least one time. And lastly, the shims permit clearances with the bearings that were hard to achieve in manufacturing without the use of shims.
