WD-45 trans and hydraulic oil?
Tony Z
05-10-2005 06:39:33
Hello everyone,
I just purchased a 1954 WD45. I was going to change all the fluids as it has been sitting for two years. I do have an owners manual. For the transmission, it calls for SAE 80EP. Being new to old tractors, what oil is that? or is something more modern recommended. Also, for the hydraulics it calls for SAE 20W. I am assuming that is motor oil, but would it be better to substitute a hydraulic oil? Thanks for any help. This is my first old tractor. Tony
Tony Z
05-11-2005 05:22:25
 Re: WD-45 trans and hydraulic oil? in reply to Tony Z, 05-10-2005 06:39:33
Thank you everyone for all the help. It is nice to have some place to ask advice.
wdtom
05-10-2005 18:16:19
There are 3 drain plugs for the transmission. One on the PTO, one under the transmission on the sheetmetal plate, and one under the differential. there are two fill plugs on the side to the rear of the hydraulic fill. You need to use all 5 to do a good drain and refill. Don't forget the final drives. Remove and clean the pans, re install, and fill to the bottom of the filler plug in the side of the pan. Same or thicker oil you put in the transmission.
wolfmantractor
05-10-2005 17:42:42
For the hydraulics I always used regular hydraulic oil (which is 20 weight). The hydraulic oil is supposed to have some additives for the seals. Regular hydraulic fluid as opposed to the hy-tran type which is used in newer tractors having hydraulic system & transmission supplied by same resorvoir. Our WD-45"s rear end gets 85-90 Gear lube.
Dave (NE)
05-10-2005 12:51:23
I use 80/90 weight gear oil for the transmission and 30 weight non-detergent oil for the hydraulics in my WD45. Note, there is a separate plug for the hand clutch, which I also use 80/90 weight gear oil.
Texas Denny
05-10-2005 06:59:39
Tony, SAE 80W is often called gear oil. It is heavy weight and can be purchsed at most auto stores and farm stores. You can use gear oil that is heavier on an old tractor but I would not go lighter. I've been using a multiviscosity gear oil that is called 85W-135W and it works very well and the gears are a bit quieter.
For the hydraulics, use 20W ND or 30W ND. The oil must be non detergent. Non detergent oils haven't been used much since the early 50's as a motor oil. You could use a good grade of hydraulic oil which is about 20w as well.
Tony Z
05-10-2005 11:59:34
 Re: WD-45 trans and hydraulic oil? in reply to Texas Denny, 05-10-2005 06:59:39
Hi,
Thank you for your answer. That helps a lot. One more question, do you know what the numbers on the hydraulic oil mean? Are they the same as motor oil? In the store I see 26,32,46 and several other numbers. Are the numbers the weight of the oil? So 26 would be the same as 26 weight motor oil? Thanks.
steve(ill)
05-10-2005 19:28:59
 Re: WD-45 trans and hydraulic oil? in reply to Tony Z, 05-10-2005 11:59:34
industrial oils are rated as 32,46,64,220. the 32 is about a 5- 10 wt. the 46 is 10 wt and 64 is 20 wt. you will get a better oil if you spend a couple dollars extra for the 5 gallon pain that says hy-trans, hy-guard, or universal hydraulic fluid. these are more for hydraulic resivouirs for tractors that run under hydraulic pump pressure. my opinion is the industrial oils are more for sumps with circulating pressure for things like air compressors or turbines. "tractor" oil is normally called hy-trans or hy-guard depending on if it meets the JD spec or others. all of these are acceptable for the WD45.
Texas Denny
05-10-2005 17:18:46
I guess that I am stumped on that one. That is why I always use 30W non detergent because I know what it is. But a lot of others use hydraulic oil and swear by it. The only two tractors that I have that use special fluid are a 901 Ford and a Case-O-Matic because both have special transmissions. The Allis's all get the gear oil and 30W Non Detergent. In the crankcase, I use 10-40w usually.
