185 transmission/rear end problems
John Kinsey
05-07-2005 07:50:41
I normally work on MM's but my neighbors 185 lost the oil from the rearend/trans and low gear siezed to the pinion shaft as well as the pinion bearings appear to be damaged (and others I assume).
My question is where do we find used parts for this tractor? We will need at least the first gear and likely the ring and pinion. I'll know more when I get it the rest of the way apart.
Thanks for any help
Doc. 301
05-10-2005 21:19:06
 Re: 185 transmission/rear end problems in reply to John Kinsey, 05-07-2005 07:50:41
I can get you new aftermarket reasonable, drop a line if interested. Larry
JMS/MN
05-07-2005 12:04:06
Parts Express has 11 yards. 1-800-533-5304
