WD45 plow up no down?
Jim in Michigan
05-04-2005 17:07:46
The wd45 I have seems to have a problem,, it was working fine, but now the plow will not go down, any ideas? I cant get the lift arms to do anything ,,,,as I said it was working ok but then stopped I got the plow up but now it wont drop,, thanks in advance,,Jim
Jim ny
05-07-2005 04:38:23
 Re: WD45 plow up no down? in reply to Jim in Michigan, 05-04-2005 17:07:46
John is Very Correct. I have had a few tractors that I have had to do that to.
John Rogers
05-05-2005 18:29:58
Jim, On the front of the pump, back of the clutch housing and about half way down on the pump is a small screw. By turning it in it will move the valve body in the pump so the oil can flow back into the sump and let your implement drop, provided that your control lever is also down. At least in 56 years of owning WDs and 45s it has worked for me. John R.
JMS/MN
05-05-2005 04:51:55
There is a decal on the right side of the battery box, as well as in the Operator Manual, that shoes how the four screws should be set for whichever operations the system is capable of. I would double check that each of these are set in the proper position, as well as checking all the components in the linkage system. Perhaps something got disconnected.
Jim in Michigan
05-05-2005 05:46:50
 Re: WD45 plow up no down? in reply to JMS/MN, 05-05-2005 04:51:55
no decal on the box anymore I have no manual,, thanks ,,,,JIm
Scott-IA
05-06-2005 08:51:40
 Re: WD45 plow up no down? in reply to Jim in Michigan, 05-05-2005 05:46:50
You need to get a manual. The reason you have no down is becuase your linkages have probably slipped, or were never adjusted right, or the detent screws you have to adjust to get the different hydrolic settings have come loose.
They're available in many places. I got mine off of ebay.
Wil
05-05-2005 10:11:01
Jim,
Try this address to Duey's website. He has the adjustments for the WD/WD 45 hydralic sytem.
HTH.
Wil
http://dueyschutter.freeservers.com/photo3.html
