WD starter
Jim-IL
05-03-2005 19:57:19
My WD starts rather hard, or I should say, turns over slowly, like you were hand cranking. Sometimes it really turns over fast like it should, but not too often, It's very irratic. I had the starter out and cleaned the connection between it and the frame. When I had it on the bench it spun fine with a battery. I replaced the switch on it as well as the battery cables. What could the problem be?
Texas Denny
05-05-2005 08:18:48
 Re: WD starter in reply to Jim-IL, 05-03-2005 19:57:19
Jim, I think I agree with Dean. The biggest problem is most likely cables.
I have a Moline ZTE which cranked so slowly that it rarely ever started with the starter - always used a crank. I put in new 1 AWG cables and it will now start on the starter. Zero AWG would be even better if you can find them - I can't and have a hard time finding 1 AWG.
Another experience is not related to tractors, but the issue is similar. I have a 1952 Ford Victoria with a flat head V8 running on 6 volts. It would only start when cold and then only occasionally. It had brand new shiny battery cables. But they were 4 AWG. I found new post cables that were 1 AWG and put those on. It started great when cold but occasionally stumbled when warm. I found another 1 awg and put it on in parallel with the existing cable from the solenoid to the starter (Four cables in the system - ground, battery to solenoid, and two from solenoid to starter). Now, the engine spins and starts in all situations. I'm going to parallel the other two cables (6 cables in all) as well which will effectively give me 00 awg cables and should effectively eliminate voltage drop in the cables.
Voltage drop in the cables causes two problems. First, it causes slower cranking speeds. And it reduces the voltage to the iginition resulting in a weaker spark. More than enough to prevent reliable starting.
big jt
05-04-2005 08:26:43
Morning Jim
Would be my guess that Dean is on the right track.
One other easy way to diagnose this is after you have been cranking feel around. Whatever the weak link is will be warmer than the rest of the system. Be careful because it may be hot enough to burn.
HTH
jt
Dean
05-04-2005 06:07:55
Assuming that your battery is good, I would suspect the battery cables and/or connections. The battery cables on many older 6V tractors have been replaced with readily available 04 Ga battery cables, which are designed for 12V automotive applications. These cables are not sufficient to handle the much higher current requirement of your 6V starter. Battery cables, both positive and negative, for 6V applications should be 00 Ga with compatible connections. If yours are not replace them. If your cables are proper 6V compatible cables but old, inspect for corrosion inside the insulation near the connections to the battery. Sometimes such corrosion is not readily visible but can seriously affect the current carrying capacity of the cable. Look for swelling of the insulation. Replace if evident.
Dean
Jerry from East Iowa
05-04-2005 05:52:30
Hi
Sounds like your strater is getting weak.If you changed all the other things out it is the only thing left.When you tested it in the vise did you put a board against the teeth and push(be careful)to see if it takes a load? My guess is it won't. And did you clean the spot where the ground cable bolts on? If you need parts or have questions please let me know. [email protected]
Thanks,
:) Jerry
Jerry's Tractor Repair
Holy Cross, Iowa
563-552-1615 or 563-590-1973
farmweld
05-04-2005 05:03:33
about the same thing that happened to me. pulled it out replaced, and works great. didnt really have enough time to troubleshoot, and its about 60 years old, i figured i couldnt loose to replace.
old
05-03-2005 20:50:55
It maybe getting weak as they get older the slow down and may need new brushes and bushes or in other words a rebuild
