Repairing a WD-45 radiator
Werner Riedel
05-01-2005 18:50:34
I'm looking for any information or tips on repairing a WD-45 leaking radiator. I have the radiator out of the tractor and need to weld it. Is it something I can solder myself or would you suggest I take it some place. If I do it myself, what type of solder would I use and can I use a propane torch to repair it?
acmfmh
05-05-2005 09:29:29
 Re: Repairing a WD-45 radiator in reply to Werner Riedel, 05-01-2005 18:50:34
Had a WC radiator that I took to a very good shop to fix. Always used them. Never a problem with their work.
Anyway the more he fixed the more that started to leak. Finally gave up. I bought a new radiator for $200. Was cheaper than letting them try and fix all of the "new" holes.
Texas Denny
05-03-2005 08:09:01
I have repaired several using a torch, flux and solder used for sweating copper pipes. I would only recommend doing this on an injury. Use a pliers to close the leak hole and do a thorough job of cleaning and sanding. Preparation contributes about 98% to success. And I might ad, this takes patience and skill.
If it leaks because of age, there may be 100 holes in the waiting near the current leak. As Gene says, you fix one and find another.
gene (Missouri)
05-02-2005 21:44:30
Werner.
Suggest taking the radiator to a radiator repair shop and get an estimate. It may be cheaper to purchase a new radiator than to repair the old one.
You can use a good flux and acid core solder to repair the radiator. Problem is that old radiators are thin and brittle. You repair one leak only to have the radiator spring another.
Gene.
