WD wont go in reverse
stickbahr
05-01-2005 10:07:22
I had a lot of play in the shifter so I welded up the worn slots an re-machined them. when its in nuetral I think because I can roll the tractor when I engage the clutch it moves. but when I shift to reverse an engage the clutch the tractor wants to die. it seems to shift in to all the other gears.
derek graham
05-01-2005 12:26:38
 Re: WD wont go in reverse in reply to stickbahr, 05-01-2005 10:07:22
sounds to me like you welded it too wide and it"s going into reverse and fourth at the same time try grinding the width down a little more
old
05-01-2005 11:11:15
Sounds like its shifting in to more then one gear when you put it in Rev. you may have something not lined up right in there
