WD45 Carb
Hendrik Alberts
04-30-2005 23:23:50
I am restoring a WD45. The carb needs to beserviced. It is a Marvel Schebler TSX-853 carb. At the bottom of the carb is a brass nut with a needle that can screw in an out. This nut is broken in half. Does annyone know where I can get a replacement for this brass nut and where I can by a carb kit to fix the carb?
Thanks
Steve in N.J.
05-07-2005 21:22:30
 Re: WD45 Carb in reply to Hendrik Alberts, 04-30-2005 23:23:50
We sell carb kits. Need the number off the tag to fix you up with the correct kit. Drop us a line if interested....
Steve@B&B
Hendrik Alberts
05-10-2005 09:09:12
 Re: WD45 Carb in reply to Steve in N.J., 05-07-2005 21:22:30
That will be great. The tag number is TSX-853 and stamped underneath is 66 F. It is a Marvel Schebler carb.
Thanks
Chuck in Tejas
05-01-2005 08:27:10
that nut comes with a full carb overhaul kit...or they did last time i bought one...MS carbs are pretty common on small fords also so finding one should be pretty easy...if you cant find the nut holler...i may have one in my junk
