bearings
dreamer
04-30-2005 20:54:39
where can i find .040 bearings for a WD-45 allis chalmers??? and also i think i am correct on this, i have a WD, and i want to put in a WD-45 crankshaft, will it work? i have an inch from TDC to the head, and the valves shouldnt open more than 1/2 an inch.
thanks for any help
wdtom
05-01-2005 17:51:59
 Re: bearings in reply to dreamer, 04-30-2005 20:54:39
It was a few years ago now, but at least the mains on my WD and maybe the rods too are .040. They are available, your crank grinder may have to look though.
steve(ill)
05-01-2005 05:33:36
you always keep the crank with the pistons. if you use a 45 crank, get the 45 pistons to go with it. you are right the 45 has a longer stroke and you will get more displacement. the WD pistons will not work with the 45 crank. i dont know about the.040 mains. you can get oversize bearings from vendors on this site or others, dont know if .040 is a standard. look to the left of this page, click on GALLERIES, then parts. if that dont work their are othere vendors. [email protected]
