Traction Booster works too good on D17 III
Rednight (IL)
04-30-2005 05:45:23
I have been using my D17 series III to pull a single shank subsoiler. It has plenty of power to sink it in but the traction booster keeps pulling it out of the ground. How do I adjust it to be a little less sensitive? Thanks for your replies.
BushogPapa
04-30-2005 19:15:02
 Re: Traction Booster works too good on D17 III in reply to Rednight (IL), 04-30-2005 05:45:23
I don't have a D-17, but if the hitch set-up is anything like a WD-45, there is a large spring under the tractor in the hitch...I removed all of the shims from the retaining bolts, to tighten the spring and it does not try to raise the front end nearly as much now....
Hope this helps..!! Ron..
