WC Fly wheel/Ring gear
Gov'nr
04-29-2005 21:19:04
Have some engine work to do and am not really familiar with this tractor yet. Once I pull the engine, how do I remove the fly wheel and ring gear from the crank?
Graybeard
05-02-2005 19:08:02
 Re: WC Fly wheel/Ring gear in reply to Gov'nr, 04-29-2005 21:19:04
When you are carrying it to the parts cleaner tank be careful to not trip over your cat. Good Luck.
gene (Missouri)
04-29-2005 21:38:56
Once the engine is out of the tractor you remove the clutch pressure plate and clutch disc (six bolts). Four bolts hold the flywheel to the crankshaft. You might need a prybar to wiggle the flywheel and starter ring gear off the crankshaft. Not a big job.
The bolts in the flywheel are (supposed to be) offset so that the flywheel can be installed in only one position.
Caution. The flywheel weighs quite a bit. I'm just guessing, 150 lbs.
Gene
