D17milky hydraulic oil
Chas
04-29-2005 21:12:37
My D17 Series III has milky colored hyd oil. I assume it's moisture. How could it get in the system? System seems to work ok but should I change it anyway? Does anyone know what type oil to use and how much?
Thanks for any help!
Don Dittmar
04-30-2005 04:38:25
 Re: D17milky hydraulic oil in reply to Chas, 04-29-2005 21:12:37
I would change it. My D14 holds 9 qts.. I use AW-68 hyd oil
steve(ill)
04-30-2005 18:59:19
 Re: D17milky hydraulic oil in reply to Don Dittmar, 04-30-2005 04:38:25
it gets in the hydraulics thru the dip stick or breather areas. use a hydraulic- transmission fluid availabe at Wal Mar or local Farm Store. MOst common is "Universal- hy- trans". it is a 20 wt hydraulic oil. sells in 2 gallon pail. you probably need about 12 quarts.
Chas
05-01-2005 06:50:01
 Re: D17milky hydraulic oil in reply to steve(ill), 04-30-2005 18:59:19
Thanks again Steve
Will change my oil.
Are you from Illinois, if so what part?
steve(ill)
05-01-2005 19:33:18
 Re: D17milky hydraulic oil in reply to Chas, 05-01-2005 06:50:01
west central Ill. Rushville
