Sickle Bar Mower on a '39 B
Chris (OR)
04-29-2005 09:16:07
I have made a bit more progress on rebuilding a sickle bar mower for my '39B. I have a few questions for someone that has really used one.... I have never used one (this style of mower) so some of these may be very basic questions....
How close to the ledger plates and knives need to be? There is a bit of an angle to some of the guards (fixed points) so there is up to 1/8" gap between some of the knives (the part in motion). Some sit against each other. All knives and ledger plates are new and riveted on. Is this why there was some rusty shim stock under a few loose guards?
Is there supposed to be a spacer or something between the draw bar and the rear wheel housings? I can bolt up the draw bar but it's not as wide (like 3/8" narrower) than the drilled/tapped holes in the housing. I really don't want that play in there. I think that I could torque the hell out of the bolts and do nothing other than snap them off... I'm not going to open up the arc of the drawbar... I have to be doing something wrong... Some sort of spacer plate or sleeves?
Thanks
Chris Horn
Scappoose Oregon
Rod (NH)
04-29-2005 11:15:37
 Re: Sickle Bar Mower on a '39 B in reply to Chris (OR), 04-29-2005 09:16:07
Hi Chris,
I suppose if you want it to be really correct, you'd adjust like this:
third party image
However, many of mine look more like the "wrong" picture :o). It still works pretty well though.
No, there's not supposed to be any spacers between the drawbar and the wheel housings. It should be a rather snug fit. Perhaps yours has been sprung in the past for some unknown reason. In any event, I wouldn't try to spring it back by tightening the bolts harder, at least w/o a lot of heat somewhere in the middle of the curvature. Stripping the threads in the housing would not be good and it would not be easily corrected.
You really should have that drawbar clamped tight however when using the mower because of the vibration involved. In fact, you should also use the turnbuckle braces that go between the drawbar and the fender/seat support angle irons. If you don't have thosae braces, perhaps you could cobble together someting to accomplish the same thing. If you are not familiar with those braces, post back and I'll post a picture.
third party image Rod
Chris (OR)
04-29-2005 16:17:32
 Re: Sickle Bar Mower on a '39 B in reply to Rod (NH), 04-29-2005 11:15:37
Rod-
I once saw a set up like the braces in question. A photo or two might help me. Please post up if you have a chance...
Thanks
Rod (NH)
04-29-2005 17:25:17
 Re: Sickle Bar Mower on a '39 B in reply to Chris (OR), 04-29-2005 16:17:32
Click on the thumbnail to bring up a larger picture in a new window:
third party image
TexMac
04-30-2005 00:12:58
 Re: Sickle Bar Mower on a '39 B in reply to Rod (NH), 04-29-2005 17:25:17
Rod,
Do you have anymore of those photos of the mower already posted? How can I access them? Don"t go to any extra trouble, but there is one in the bushes at my Dad-in-law"s place and I have considered resurrecting it if the pieces are all there. I just would like to see what it looks like.
Rod (NH)
04-30-2005 07:53:54
 Re: Sickle Bar Mower on a '39 B in reply to TexMac, 04-30-2005 00:12:58
Hi,
There are a couple of photos here but none are close up. Unless the unit has been cannabalized, the "loose" parts are as follows:
1. PTO drive pulley
2. Drive V-belt
3. Drawbar supports
4. Tapered spacers that go on drawbar
5. Large washers that go on top of tapered spacers - used to adjust belt tension
6. Lower driven pulley guard
7. Misc. attaching bolts, etc.
Many times these parts get lost in the shuffle, unfortunately. Numbers 1 thru 5 show in the picture I posted previously in this thread. Number 6 is not important as far as I am concerned. I have it but never use it. Number seven can be easily obtained - normal hardware items. Number 2 can also be obtained easily locally. Numbers 1, 3, 4 and 5 are the more important pieces that make it difficult if you don't have them. The functionality of those can be cobbled together if needed and wanted bad enough.
Here's a thumbnail of a diagram that may help. The B and C mowers are basically the same. The manual and hydraulic lift mechanisms are a bit different:
third party image
I don't have any pictures of it off the tractor. It is now on the tractor and will be for the indefinite future. If there is something more specific you'd like to see in a closer picture, let me know and I'll grab a photo or two for you.
TexMac
04-30-2005 10:06:01
 Re: Sickle Bar Mower on a '39 B in reply to Rod (NH), 04-30-2005 07:53:54
Just what I needed. Thanks. Mine is also a "39. Everything is manual!
old
04-29-2005 10:27:55
Been a long time since I have played with one of them. But you should have all the section on the bar also touching the guards, maybe only a sheet of paper away from them
Chris (OR)
04-30-2005 16:31:38
 Re: Sickle Bar Mower on a '39 B (photos) in reply to old, 04-29-2005 10:27:55
This is a good web page that has a bunch of close up photos of one....
