Timing my B for Rod (NH)
TedBoss
04-28-2005 13:48:25
Rod, thanks for all the help. I put the drive gear back in using the process I told you about. It fired first time. I checked it with the timing light and I am very close. I think I may be one tooth off on the gears because when I turn the mag to advance the timing (which it needed), I can only get the FIRE mark to the top 1/3 of the timing hole. I guess that means I need to go back and move my drive gear by one notch so I can get it timed and say about mid way in my adjustments on the mag. I did adjust my carb and that made things run much better also. I still have a miss on the number one hole that is not consistant, but you can hear it and see it with the timing light. Any thoughts about the missing. Like I said, it only misses on number one. Thanks for all your help. Ted
Rod (NH)
04-28-2005 17:22:52
 Re: Timing my B for Rod (NH) in reply to TedBoss, 04-28-2005 13:48:25
I'm glad you got it running Ted. The thing that comes to mind on a miss in one cylinder would be sparkplug. The first thing I would do in install some new plugs if you haven't already done so. I've had excellent luck with NGK B-4.
Rod
TedBoss
04-28-2005 18:35:18
 Re: Timing my B for Rod (NH) in reply to Rod (NH), 04-28-2005 17:22:52
I will change them out tomorrow. I did put now ones in when I did the rebuild, but you never know, could have dropped it or could be bad from the factory. I think they are autolites in there now. I am going to get my pics posted one of these days now that I am done. Thanks for your help!
Ted
TedBoss
04-29-2005 13:18:41
 Re: Timing my B for Rod (NH) in reply to TedBoss, 04-28-2005 18:35:18
I put the new plugs in and did change the drive gear in the mag. I retimed it and runs great. I want to thank you very much for all the help! I will post pics in a week or so.
Ted
