WD 45 and a hay fork
Chad Berberich
04-27-2005 13:58:28
Can I put a hay fork on a WD 45 and is the tractor heavy enough to handle moving a typical round bale (say, 1,200 lbs)?
Sid
04-27-2005 22:16:56
 Re: WD 45 and a hay fork in reply to Chad Berberich, 04-27-2005 13:58:28
I have seen them used with loaders and rear carriers. A guy I know has a bale carrier built to use with the snap coupler. I have used it on my WD and have used a three point adapater with a bale carrier. The homemade snap coupler will lift them easier and will not lighten the front end as much as using a three point adapter. Bale sits closer to tractor
old
04-27-2005 21:21:03
You talking about putting it on the 3 point or on a loader?? If loader it should do well, but if on the 3 point you may have to put some weight up front. Other wise it should do ok
bc542
05-03-2005 18:12:21
 Re: WD 45 and a hay fork in reply to old, 04-27-2005 21:21:03
i have forks on a wd and it handles it really great you should be fine i use mine everyday to move hay to the cattle and horses its not yet failed in 14 years
old
05-03-2005 20:38:42
 Re: WD 45 and a hay fork in reply to bc542, 05-03-2005 18:12:21
I can depend on the bale, if you where trying to move one of my bales you would probably have trouble.
