WD-45 Differential Gears
Phill Snartland
04-27-2005 11:13:11
Hi Everyone,
I'm restoring a 1954 WD-45. I intend to use it for plowing and field work as well as parades and towing.
I've done a lot of work already and just as I was about to button up the rear end, I found that teh two spider bevel gears in the differential are worn very badly.
Does anyone have a set of these small bevel gears (and the shaft they spin on) in good condition? Does anyone know of a source for replacements or a cross-match to another tractor or another vehicle (truck, car, etc)?
Thanks for any help!
Phill Snartland
St. Cloud, MN
JMS/MN
04-28-2005 10:58:01
 Re: WD-45 Differential Gears in reply to Phill Snartland, 04-27-2005 11:13:11
Mechanic/collector friend of mine is half hour east of you at Milaca. 320-983-3500. I also have an extra WD differential- most parts are the same, but not all. Popped the cover off of it this morning and gears/shafts look good. Big issue other than price is time involved to dissamble. If interested in buying parts or the bare assembly with internal parts- just post here. Don't need your number, it's local for me, or I'll call you in a few days.
Phill Snartland
04-28-2005 11:01:11
 Re: WD-45 Differential Gears in reply to JMS/MN, 04-28-2005 10:58:01
Thanks, JMS, I did locate a set of gears that are supposed to be in good condition. I'll know in a few days when they arrive. Are you located in Milaca, also? It'd be fun to get together sometime to share stories.
Phill Snartland
St. Cloud
JMS/MN
04-28-2005 20:45:46
 Re: WD-45 Differential Gears in reply to Phill Snartland, 04-28-2005 11:01:11
I am half hour SW of you. Grew up with AC,farmed over 30 years with AC and JD. Have a few of each for hobby tractors. Will call you soon- I have many contacts for parts, etc., and will be glad to share them with you.
