D14 governor surge
Don Dittmar
04-26-2005 04:35:27
I just fired up the D14, it runs like a watch. I am having problem with the gov. though. It idles just fine, but when you start to rev the engine up it will eventually rev up, but it surges real bad. I had the orginal AC anti surge spring on the carb rod, and i replaced with a stiffer one from the hardware just for kicks, but it did not help. The book says to adjust by bending the rods. Is this adjustment what i need to do?? If so which rod do I bend??? I can get full rpm, it just wont stay there. Spring on the right side of the tractor is new, and I replaced one weight when I Overhauled it because it looked beat up.
