leeking Eaton power steering pump
Eli
04-25-2005 19:16:28
My pump started leaking behind pulley. I took the pump off and the shaft moves in and out about 1/8th inch. There isn't any side to side play. This happend all at once. What happend? Where can I get parts? Thank You Eli
Bob
04-26-2005 10:50:46
 Re: leeking Eaton power steering pump in reply to Eli, 04-25-2005 19:16:28
The end play you are seeing is NORMAL. Replace the shaft seal, and all will be well!
An industrial bearing and seal place or a hydraulic repair shop should be able to find you a seal by cross-referencing the numbers on the old one, or by the dimensions.
Eli
04-26-2005 17:41:49
 Re: leeking Eaton power steering pump in reply to Bob, 04-26-2005 10:50:46
Thanks Bob thats what I will do. Eli
