Fires on only three
Korggdns
04-23-2005 18:26:25
I just got back togeather my Allis B after having the engine completely rebuilt from the top down. After getting the timeing close to perfect it started and runs great only on the first three cylinders. Number four fires fires perhapes once every ten seconds. Swaping plugs and wires between cylinders has no effect. There seems to be good spark when pulling the wire from the distributor cap. All valves check out at .010 clearence. What did miss?
Ed H.
04-27-2005 07:28:18
 Re: Fires on only three in reply to Korggdns, 04-23-2005 18:26:25
sounds like you may have a valve sticking or a weak valve spring or both.....did you put new guides and valves in?....maybe one is a little tight?
jayw
04-25-2005 14:29:16
does it seem too level out when you hold the wire away from the plug and let the spark jump? If it does you could very well have a bad plug I have had that happen with Champion plugs right out of the box.
gene (Missouri)
04-23-2005 21:30:52
Take a compression check on all cylinders. Something could be keeping a valve from closing.
Gene.
steve(ill)
04-24-2005 06:36:45
 Re: Fires on only three in reply to gene (Missouri), 04-23-2005 21:30:52
if you have eliiminated the wires and plugs, yes, tight valve stem would be my guess also.
Korggdns
04-25-2005 19:08:39
 Re: Fires on only three in reply to steve(ill), 04-24-2005 06:36:45
When holding my finger over the spark plug hole it seems to have compression. I will get a hold of a compression tester and get a precise reading.
Gatz
04-24-2005 17:34:14
Check the distributor cap inside and out for hairline crack(s)
especially around #4 wire tower.
Korggdns
04-25-2005 19:16:08
 Re: Fires on only three in reply to Gatz, 04-24-2005 17:34:14
I swaped the dist. cap from a spare magnito that I have and has no affect. I also checked all the valve clearences (.010") --still no affect; still stumped.
Gatz
04-26-2005 19:22:20
 Re: Fires on only three in reply to Korggdns, 04-25-2005 19:16:08
Intake manifold and/or gasket leakage ?
