CA PTO leak
Dave Jewell
04-22-2005 06:27:15
Hydralic fluid started leaking around my PTO shaft. It was a steady stream. I removed the four bolts holding the round cover that slides over the shaft, there were two shims behind it,the fluid was coming out of the bottom bolt hole. Does anyone know what I need to do to fix this?
Dale(MS)
04-23-2005 06:27:02
 Re: CA PTO leak in reply to Dave Jewell, 04-22-2005 06:27:15
Dave, Shoudn't be to big of a problem. Get a new seal for the PTO shaft and a gasket for the seal retainer plate. Replace the shims and put it back together and use some thread sealer on the four bolts that attach the retainer plate to the housing. Dale
