WC serial number and camshaft
shaun esbenshad
04-20-2005 17:15:17
First off with the serial number i can hardly read.the numbers that i think they are are 16269. but i cant find it on the wc serial number list.Can anyone help me out. also i have a camshaft prob. the gear that drives the oil pump on the cam is striped.so do i have to get a whole new cam?.or does it come apart. someone told me that in order to get the came out i have to disconnect the lifting rods or piston rods ? is that true? any help is appreciated . thanks
Aaron SEIA
04-21-2005 14:59:58
 Re: WC serial number and camshaft in reply to shaun esbenshade, 04-20-2005 17:15:17
A serial number that early would make it a 1934 I think. As for the cam, you need a new one. Need to drop the pan and remove the oil pump. Take the side plate off of the mag side of the engine, thats where you get access to the lifters. Also need to remove the valve cover and loosen the rocker arm assembly and remove the front cover and radiator. You should be able to hold all 8 lifters up with clothes pins or something so you can remove the cam. If not, guess you can have your wife or a buddy help slip them back in from the bottom when you reinsert the new cam. I think I have one laying around that I'd sell. Not a real hard job to do. Easier if the engine is out, but I know it can be done with the engine in-frame.
Aaron SEIA
