transmissin on ca
patex
04-20-2005 09:25:52
sometime when I shift from first gear to reverse my transmission goes into 3rd or 4th gear. the shift lever is in neutral nnd won't go anywhere else. the transmission is hung. can anybody help, thanks
steve(ill)
04-20-2005 19:29:17
 Re: transmissin on ca in reply to patex, 04-20-2005 09:25:52
on the right side of the trans, across from shift lever there is a round cover plate with 4 bolts in it. the shift forks are mounted on rods behind the cover. drain the oil down, remove the plate with shifter in neutral, and look at the rod and forks. something is loose, worn or bent.
