Model B Electrical Circuits
Rick Hester
07-03-1999 04:40:31
I am a novice at old tractors, so please don't laugh at what may seem simple questions.
On my 1950 Model B, the electrical circuits have been cut, taped, resoldered, rerouted to the point that it doesn't look anything like the wiring diagram in the serivce manual that I bought through YT magazine. It is a 6 volt battery ignition, positive ground. I want to leave it that way just because.
Question 1: The 3 position light switch is gone, of course. I want to substitute toggle swithches since I can't find a a good original or new replacement light switch. One toggle will control the lights (on - off switch), and one toggle will control the charging rate (on - off - on)with one circuit being direct ground for high charge and with the other circuit with a resistor for low charge.
Do you see any problems?
Question 2: How do you alter the charge rate for my Delco-Remy 3 brush generator? The service manual points to a bolt on the back of the generator and says to loosen the bolt and move the third brush in the direction of rotation to increase the output. What do I move? I don't see anything moveable on the outside of the generator except a wide metal band. Is the third brush attached to that band, and is that what I move?
I assume that I will adjust the charge rate with the 3 position toggle set at high charge (direct ground) until I achieve 10 - 12 amps.
Question 3: What size resistor should I use to achieve the 10 - 12 amps at high charge and 3 amps at low charge? If I plug the numbers into Ohm's law, I get 2 ohms resistor (R=V/I or R=6 volts/3 amps desired or R=2 ohms). Is this correct?
Question 4: I want to use a third toggle to control the ignition (on - off). Please verify my ignition circuit: The primary ignition wire will run from the negative terminal of the battery at the starter to the toggle switch to the coil to the distributor. Is this correct?
Thanks for any help. I am a real idiot at electricity.
gordon Chance
07-03-1999 12:55:37
 Re: Model B Electrical Circuits in reply to Rick Hester, 07-03-1999 04:40:31
Rick: I will try to answer your questions. On question 1 I don't see any problem as long as you find the right size resistor and have enough room to mount all of the switches in the instrument box. On question 2. You have to remove the band from the generator in order to adjust the 3rd brush. With the band removed you loosen the screw on the back plate so that you can move the third brush to get 10 to 12 amps at high charge. When you have the rate set you tighten the screw to lock the brush in place and replace the band. On question 3. I think that you are correct in using a 2 ohm resistor to achieve the results that you want at low charge. On question 4. The wire running from the negative battery cable at the starter switch should run to the ammeter first with another wire from the other post of the ammeter to the ignition switch. The rest of the wiring circuit is correct. I hope that I have answered your questions. Gordon
