Model C PTO
Jim and Deb
04-19-2005 18:09:33
I am looking to buy a PTO and in the photo of the PTO, it shows a pulley sticking out of the side of it along with the PTO output shaft. Does the pulley operate independantly? Or does the pulley and PTO operate simultaneously?
Thank you very much in advance
Jim 'n Deb
hector gemme
04-20-2005 15:57:40
 Re: Model C PTO in reply to Jim and Deb, 04-19-2005 18:09:33
HI I have a allis chalmers serie CE194184 PA whit loader allis and poly in bacleft side and pto and hydrolique for sale.
Brett Phillips
04-19-2005 18:53:05
They operate simultaneously. In addition, the hydraulic pump also operates only when the PTO/Belt Pulley are in gear. If you are looking for a complete PTO/pulley unit, keep in mind that modern implements use a 1-3/8 diameter spline, and most of the B/C PTO units are 1-1/8 diameter. You can use an adapter sleeve, or better yet, use an over running clutch that adapts from 1-1/8 to 1-3/8. If you are lucky, you may find a PTO unit from a late model B with a 1-3/8 shaft from the factory. Even then, plan to use an over running clutch if you'll be using an implement with a lot of inertia, like a brush hog.
Hope this helps,
Brett
steve(ill)
04-19-2005 19:35:00
 Re: Model C PTO in reply to Brett Phillips, 04-19-2005 18:53:05
in addition, the pto on the rear runs 540 rpm, the side shaft (belt pulley) runs 1000 rpm at rated motor speed. one engagement lever for both.
