COIL AND IGNITION FOR WD45
ROBERT KRUEGER
07-02-1999 20:22:35
I HAVE A WD45 CONVERTED TO 12VOLT NEGATIVE GROUND SYSTEM. I HAVE 2 IN-LINE RESISTORS LOWERING THE VOLTAGE TO THE COIL TO ABOUT 8 VOLTS. WOULD IT BE BETTER TO USE A 12 VOLT COIL AND USE 1 OR 2 RESISTORS BETWEEN THE COIL AND DISTRIBUTOR?
