Rebuilding AC7030
Jason Baugher
04-16-2005 20:46:26
We bought a rebuilt shortblock and are just about ready to fire it up. There is a restrictor valve beside the oil filters that according to the manual is used to adjust the engine oil pressure. However, there is nothing in the manual giving us a starting point. I'm hesitant to start the engine up if I'm either not providing enough pressure or providing too much.
Does anyone know a good starting point? X number of turns in, perhaps?
Thanks
dsldr
04-17-2005 04:59:53
 Re: Rebuilding AC7030 in reply to Jason Baugher, 04-16-2005 20:46:26
I normally put all the engine oil in by using an external pressure luber tank before starting a fresh overhaul. This guarantees that oil is present everywhere in the lube system. As for a starting point, who knows, but I think I would turn in the screw against the spring until I knew I could feel resistance from the spring, and then go a couple more turns. Get yourself right handy at the adjustment, and raise or lower it when it fires. Keep in mind: many more engines are ruined by low or no oil pressure than a few seconds with too much oil pressure. Just my experience. Good luck.
