WD-45 PTO IDLER GEAR SHAFT INSTALLATION
JAMES/MN
04-16-2005 20:27:38
My idler gear shaft is 3-5/8" long. The shaft has 1 indentation where key is placed. Each side of pto housing has a cutout for key or pin. The Serivce Manual says to ""enter shaft from the front and push into place//The shaft with the retaining pin will not go into housing without grinding off top of pin slightly//With either shaft (pin or woodruff key) peen keyway slightly to retain shaft in housing.""
I cant get the shaft to snug-up in the pto housing! I only have the woodruff key and not the pin--is this the problem perhaps?? What does the service manual mean by "peen keyway slightly"?? How much of the pin do i grind off??
I am confused!! Can somebody help???
Thanks
