AC model G fluid
R. Mizell
04-15-2005 08:50:28
What is the weight of the differential/transmission fluid for the Allis Chalmers model G? I looked in my reproduction manual and it said 20W transmission fluid. I know that can't be right. I assume 80W-90 gear lube would work but I don't like to just assume.
Thanks,
R. Mizell
DanD.
04-15-2005 13:22:39
 Re: AC model G fluid in reply to R. Mizell, 04-15-2005 08:50:28
The 20wt recommendation is correct. THere is at least one bearing in the G transmission that is lubricated by oil thrown from an oil slinger. Thick gear lube won"t get there properly. One of the modersn trans-hydraulic oils would work great even if your G doesn"t have hydraulics on it.
Joe M (GA)
04-15-2005 09:02:31
80/90 would be fine without hydraulics, with hydraulics I"d use 30wt non-detergent
steves(ill)
04-15-2005 18:54:18
 Re: AC model G fluid in reply to Joe M (GA), 04-15-2005 09:02:31
the transmission is about the same as a B ro C. original fill was 20 wt oil. new standard for most tractors these days is the universal hydraulic- transmission fluid. anything will work, even motor oil, but the hy-trans is non foaming, rust inhibitors, good for hydraulic systems, bearing lube, and it dont cost much either. it is a 20wt viscosity oil.
