WD versus WD45
rdmace56
04-15-2005 06:14:14
There is a WD45 listed on Ebay. Photo shows A113859 on casting. Is there a way to spot the differences between a WD and WD45? Was is just a engine upgrade?
John (MO)
04-15-2005 09:54:32
 Re: WD versus WD45 in reply to rdmace56, 04-15-2005 06:14:14
There are at least 9 WD/WD45's listed on Ebay, but I didn't find a mention of the number A113859, I may have overlooked it or not found the right tractor. Denny is exactly correct about the transmission shift lever and the plate on the side of a WD engine. Those are for sure signs of what the tractor is now at least. These tractors are over 50 years old now, and many, don't have original engine blocks in them. The WD and WD45 blocks are pretty much interchangable. You can build up a WD engine with WD45 parts to produce the same hp as a WD45, it was and I suspect still is comon practice to do this when an overhaul is needed. Biggest thing is to make sure the transmission does not jump out of gear. That can be an expensive fix.
rdmace56
04-15-2005 11:47:41
 Re: WD versus WD45 in reply to John (MO), 04-15-2005 09:54:32
the tractor is listed for Tipp City, Ohio. Sounds like WD versus WD45 is not a big deal. II asked the seller about overall operating condition. As often happens, the price is going up so it may not actually be such a deal that I would drive that far or take the risk. Does look pretty clean for the age in photos.
John (MO)
04-15-2005 14:05:58
 Re: WD versus WD45 in reply to rdmace56, 04-15-2005 11:47:41
It's not a bad looking tractor. I wish the pictures would enlarge that would help some. I would also rather see a tractor before it was painted, that tells much more the real story. It looks like the seller is an auctioneer, selling the tractor for his father. At least that's what he'd like us to think, who knows may be exactly correct. If that is the case, I kind of wonder why he doesn't sell it locally where people can see it, hear it run, and all that? From the pictures, it looks to me like the tractor was cleaned up pretty good before it was painted, and also that there is not a lot of overspray on the tires and such. Painting over grease and getting paint all over stuff it doesn't belong on pretty much tell tale signs of a Dupont overhaul to me and I figure that is done to make it look flashy to someone who buys on looks alone. If the tractor runs good and the transmission does not jump out of gear, I think its a fair deal for both buyer and seller, up to $1500 or so. But if it gets closer to $2000, then if it were me, I'd have to see it in person first.
Texas Denny
04-15-2005 07:21:59
All WD-45 tractors have a curved shift lever. However, Some late WD's also have this transmission and shift lever. All WD's have a metal plate on the right side of the engine that runs the length of the engine and is 5 or 6 inches high. No WD-45 has this plate - the block is smooth from the oil pan to the head. I think I looked at this ad. That number is not the serial number. It may be the motor number. If it is the same one I'm thinking of, about five people have tried to correct the seller who ignore every comment and continually repeats the wrong number.
