Set float level of AC G Marvel-Schebler carb
Dennis of KC
04-14-2005 08:12:39
I have a 49 AC G with Marvel-Schebler carb. I have replaced carb float, seat, and needle valve and the carb still overflows with gas. How do I set the float height? How do I measure the proper float height causing it to overflow and idle poorly? The engine is totally overhauled.
topsarg
04-16-2005 03:48:08
 Re: Set float level of AC G Marvel-Schebler carb in reply to Dennis of KC, 04-14-2005 08:12:39
Dennis:
I think your problem is debris. Remove your gas fitting that goes into the carb,remove needle and seat and do a very good cleaning of that area, and of course the lines and all from the tank. Be very thorough!!!!wash it out with the spray carb cleaner, and catch in a clean container. I think you'll be surprised... My experience..or 2 cents worth...
Ronnie in Tex.
04-14-2005 08:45:40
Set float level link.
Dennis of KC
04-19-2005 11:01:03
 Re: Set float level of AC G Marvel-Schebler carb in reply to Ronnie in Tex., 04-14-2005 08:45:40
I set float level per Glen of Tx. No more overflow and tractor idles great. Thank you to everyone who provided their opinions and help. Dennis of KC
Glen in TX
04-14-2005 22:02:32
You're getting good at this. lol. Need to sell instructions to makers of kits. They quit putting instructions in the kits for the TSV. We got the other one you helped on running fine. Thanks.
Dennis H
04-14-2005 14:07:01
Could someone tell me the float setting for a 1939 Alliss Chalmers RC with a zeinth carb. Denny
Glen in TX
04-14-2005 22:13:48
 Re: Set float level of AC G Marvel-Schebler carb in reply to Dennis H, 04-14-2005 14:07:01
Dennis, Give me some model numbers or letters and I can tell you on the Zenith. Should have some numbers in a circle on a round brass tag or stamped someplace in a circle.
