1943 Model C Hydraulic Pistons won't retract
ojiadog
04-13-2005 19:53:45
I recently restored my 1943 Model C. I made no modification to the hydraulic system other then replacing the hydraulic hoses. I then replaced the hydraulic fluid per specs. Upon first actuating the hydraulics, the pistons extended properly, but I can"t make them retract.
Any thoughts as to why this is occurring?
vince h
04-14-2005 08:30:07
 Re: 1943 Model C Hydraulic Pistons won't retract in reply to ojiadog, 04-13-2005 19:53:45
Have you tried lowering them by pushing on them. The cylinders should be single acting, which means that they are powered in only one direction and must be retracted be a load. Under normal use the wieght of the attachment will retract the cylinders. If you can't push them back in, make sure the hoses you replaced don't have a check valve built into them that would prevent the oil from flowing in the reverse direction.
ojiadog
04-14-2005 21:28:58
 Re: 1943 Model C Hydraulic Pistons won't retract in reply to vince h, 04-14-2005 08:30:07
I can not physically push them back in. I might try backing up to a tree or something?? They are both extended and I thought I remember that one would extend while the other was retracted and visa versa. I am sure the hoses do not have a check valve in them.
Tx Allis Man
04-15-2005 17:02:39
 Re: 1943 Model C Hydraulic Pistons won't retract in reply to ojiadog, 04-14-2005 21:28:58
As best as I can remember the pump on my C only is a pressure pump and my one cylinder will not retract by the use of the pump.
1755
04-16-2005 19:53:23
 Re: 1943 Model C Hydraulic Pistons won't retract in reply to Tx Allis Man, 04-15-2005 17:02:39
Our CA has simular deal we put new hoses on and have one cylender for the belly mower with the mower on it works fine with out the mower you extend the cylender then I can jump and hang on the lift system nothing whait an hour and I can shove it in with my foot
Tx Allis Man
04-17-2005 14:55:35
 Re: 1943 Model C Hydraulic Pistons won't retract in reply to 1755, 04-16-2005 19:53:23
Sounds like the pump may have a pressure releif valve sticking.
