Question about C Allis Hyd pump
Tx Allis Man
04-13-2005 14:12:08
On a 41 C allis how many gpm is the factory hyd pump that is driven by yhe pto. Was wondering if it had enough pressure and gpm to run a hyd mower.
steve(ill)
04-13-2005 15:47:08
 Re: Question about C Allis Hyd pump in reply to Tx Allis Man, 04-13-2005 14:12:08
no it will not run the mower. factory pump is about 3000 psi, but only puts out less than 1 gallon per minute. the trans/ hydraulic case only holds 2 gallons so it is too small to do much more than one or two small cylinder.
Tx Allis Man
04-15-2005 16:26:58
 Re: Question about C Allis Hyd pump in reply to steve(ill), 04-13-2005 15:47:08
Thanks for the info. Guess ill try something else.
