engine swap
fredinpa
04-13-2005 11:24:52
is there alot of trouble putting a 160 cu in series II engine into a c a allis? thank you in advance
Don Dittmar
04-13-2005 12:59:10
 Re: engine swap in reply to fredinpa, 04-13-2005 11:24:52
Fred,
Dont take me to heart on this, but it should bolt in. As far as linkages and the like, i am not sure on. the 160 was bored 149, and AC used the 149 in the d10 and d12 series 2 and up, and those tractors replaced the b and c, so it should bolt to your tourqe tube
Texas Denny
04-13-2005 20:59:36
 Re: engine swap in reply to Don Dittmar, 04-13-2005 12:59:10
Don, can the transmission and rear end take the increased horsepower of the 160 engine? I think that drive system was designed when the C developed only about 20 horsepower. The 160 put out 40 horsepower. I worry about that if used hard. But then I guess the C is so light, it would be difficult to use it hard.
Don Dittmar
04-14-2005 04:40:28
 Re: engine swap in reply to Texas Denny, 04-13-2005 20:59:36
I doubt it would take it in a hard pull. The final drive gears are much bigger in a d15 than a c, and in a hard pull, something has to give
Tx Allis Man
04-15-2005 16:29:17
 Re: engine swap in reply to Don Dittmar, 04-14-2005 04:40:28
How about a D 10 engine. How much difference is there between the c and d 10 engine?
Don Dittmar
04-16-2005 04:31:28
 Re: engine swap in reply to Tx Allis Man, 04-15-2005 16:29:17
If it is a d10 series 1 it would be 138ci, if it is a series2, it would 149ci, same as the d14. d10, d12, d14, and d15 are all the same block, it is just the bores are different and all will bolt to the "c"
tx
04-17-2005 14:57:13
 Re: engine swap in reply to Don Dittmar, 04-16-2005 04:31:28
Thanks for the reply Don. Would like to find more power for my C without overpowering the trans or pto.
