Oil Filter Element Tube missing
Tramway Guy
04-11-2005 16:30:49
Just got around to checking why my newly acquired WD45 has very, very low oil pressure. Turns out that the filter element tube (the one that goes up into the filter) is gone. Is this a dealer part, or does someone have dimensions to make one that they would be willing to share?
Steve in N.J.
04-11-2005 18:56:11
 Re: Oil Filter Element Tube missing in reply to Tramway Guy, 04-11-2005 16:30:49
We have em' new if ya need one....
Steve@B&B
[email protected]
Rod (NH)
04-11-2005 17:39:29
Hi,
That'll do it! I copied the following from a post here quite a while ago that was for a B. I can't verify it or know if the WD45 is the same but am posting it for what it's worth. If your WD45 uses the same filter as a B (say Fram C159) I would expect the tube to be same. Just don't use any of the newer design NAPA 1101 filters.
It is 1/4" OD tubing. It is 3 3/4" long (above the extended base) The hole in the top is .118 Dia. 1/4" down from the top is the center of a hole .085" drilled through both sides.
third party image Rod
Tramway Guy
04-11-2005 17:48:20
 Re: Oil Filter Element Tube missing in reply to Rod (NH), 04-11-2005 17:39:29
Thanks!
