WD-45 New Carb
Carey14
04-11-2005 07:09:57
Hello, I just installed a new Zenith carb on my wd45..... ..
and Im havinbg an adjustment problem.....
I think its in the linkage somewhere..
Here is what it is doing, after startup it goes directly to (supersonic) full throttle
any suggestions as to baseline linkage settings????
WCMARK
04-12-2005 06:49:30
 Re: WD-45 New Carb in reply to Carey14, 04-11-2005 07:09:57
Sounds like the throttle butterfly on the new carb. is backwards. I did a carb. replacement on a tractor one time and it did the same thing. Come to find out the carb went to full throttle upon start up. Found out the carb. operated in the oposite direction as the gov. linkage. If you take the throttle butterfly off and turn the rod 180 degrees and reinstall the butterfly it should work.
Craig Carey
04-12-2005 07:31:09
 Re: WD-45 New Carb in reply to WCMARK, 04-12-2005 06:49:30
Hmmmm..... I will try it tonight and let you all know if that is the culprit or not.....
thanks for the advise
CraigCarey
04-18-2005 12:35:06
 Re: WD-45 New Carb in reply to Craig Carey, 04-12-2005 07:31:09
That wasnt it...its still running full tilt.....
sounds really good but still, running way to fast
