HD7 Trac Removal?
JJay
04-10-2005 20:18:30
How do I get the pin out? can I use heat? what holds it in?
JJay
04-12-2005 07:01:09
 Re: HD7 Trac Removal?Come on Guys Please HELP. in reply to JJay, 04-10-2005 20:18:30
Thank you for responding Hector,I`m still a little
confused. What is a pine hammer? and where do I knockwit the big mass? Please Help Thanks JJay
JJay
04-13-2005 07:39:13
 Re: HD7 Trac Removal?Come on Guys Please HELP. in reply to JJay, 04-12-2005 07:01:09
Thank you Hector for responding,it`s been rain`n
here the last couple days and the HD7`s in a muddy field, but soon as we get a brake in the weather we`ll try knockwit a 16lb. hammer.
Thanks JJay
hector gemme
04-12-2005 10:02:10
HI The hammer pine it only a metal rod about 4or5 foot long and you welded on pine smaller off the master pine. One guy hold themetal rod and the second guy is knock whit a 16lbs masse .good luck HECTOR
hector gemme
04-11-2005 01:42:55
 Re: HD7 Trac Removal? in reply to JJay, 04-10-2005 20:18:30
HI You put the master pine back the sprocket and you have to be tow guy ,one whit a pine hamer and the second guy knockwhit a big mass.I have some use hd7 parts.HECTOR
