190xt tractor
Scott(nc)
04-08-2005 19:06:40
Looking for a person named Merle Gaskins who has fix a same problem with a 190xt tractor that I have if Someone knows how I can contact this person let me know Thanks
Nahtan Webb
04-09-2005 18:15:03
 Re: 190xt tractor in reply to Scott(nc), 04-08-2005 19:06:40
Don't know him but I have a 190xt what kind of problem are you having?
scott(nc)
04-10-2005 07:07:59
 Re: 190xt tractor in reply to Nahtan Webb, 04-09-2005 18:15:03
All the hyd. fluid is being pumped into the transmission side of the tractor.A few people have told me it is a seal inside the case and the only way to fix it right is to split the tractor apart. another way is to connert the two drain plugs together and to knot out a freeze plug so the two compartment become one. I have done this and just wanted to know if I did it right. So far it is running good.Hope I did it right hay season is just around the corner. Scott
Nathan Webb
04-10-2005 07:17:28
 Re: 190xt tractor in reply to scott(nc), 04-10-2005 07:07:59
Had the same problem with mine. I had a guy pull it apart and replace the seal. Man was it a job. I wish I had known about this quick fix would have saved alot of time and money, Good Luck Nathan
