Mounting an Allis G Plow
RJ Unrien
04-08-2005 07:53:33
I got an Allis G from my wife's parents and have used it around our tree farm. It came with a single bottom plow. I have never mounted the plow but would like to now. Can anyone tell me how the plow mounts on the tractor?
Dale(MO)
04-09-2005 07:02:08
 Re: Mounting an Allis G Plow in reply to RJ Unrien, 04-08-2005 07:53:33
RJ,
You get the plow under the tractor, between the front and back wheels on the right side (as long as it is a right-handed plow, they made both). Take the linkage under and around to the front of the front axle. There should be two straps with four bolts on the linkage. You bolt this to the front axle. Then you bolt together the linkage from that front piece to the linkage arm coming from the plow. Put the chain hook on the tractor lift arm, hook the chain from the plow in it, and you're ready. Also, you will have to adjust the front wheel, so that it will travel in the backfurrow. It will have to be run out to the next set of holes (if it is not already). Not much to it, the first time takes the longest. Good luck!
