Trouble with distributor and timing
patrick becker
04-06-2005 17:02:12
On a d15 series 2 I have a loader and so can't see the timing marks in the sight hole to flywheel. Any other way to time? Also the distributor has about 1/4 inch of play in it. Does that mean a new or rebuilt one needed?
DanD.
04-07-2005 17:10:39
 Re: Trouble with distributor and timing in reply to patrick becker, 04-06-2005 17:02:12
On my father's D17 with a loader, a small mirror allows you to use the timing light and see the timing mark.
gene (Missouri)
04-06-2005 23:09:03
Get out the I&T manual. There is a paragraph on double checking the valve timing. If you use this paragraph you can use the valve gap to set the #1 cylinder on TDC. Once you have the engine on TDC use two pieces of tape, one on the fan belt pulley and one on the engine front cover. Mark both pieces of tape directly across from each other. Now you can time the engine with a timing light using the two marks on the tape.
1/4 inch play in the distributor. If you are talking about moving the rotor - that's probably the springs on the spark advance.
Gene
