B Allis Engine Question
Tom in Michigan
04-05-2005 17:12:35
What is involved in replacing the front main seal on the engine? Can this repair be accomplished with the engine left in the tractor and pulling the front cover and pulley. Tom
Rod (NH)
04-05-2005 17:31:14
 Re: B Allis Engine Question in reply to Tom in Michigan, 04-05-2005 17:12:35
Hi Tom,
Sure, you can replace the front crank seal w/o removing the engine. You'll need to block up the torque tube because the front axle and support has to be removed in order to remove the front cover. The engine will overhang the support you provide w/o a problem. I use heavy timber pieces for such blocking.
third party image Rod
