WD Ser. No. Problems
Rob Bush
06-03-1998 12:38:53
I just bought a wonderfull little WD at a farm auction. To check the year, I looked to find the ser. No. on the rear end. There is no number and looks like there never was one either. The number on the side of the block says 45-35490-G. It has no traction booster. Does that mean the moter is out of a WD-45? Is there any other place on the tractor to find the year? Is there such thing as a WD originally not having a ser. No. on the rear end. It has no "snap-coupler", so it has to be early.
Thanks Alot For Any Responses,
Rob Bush
DJ
06-04-1998 18:37:39
 Re: WD Ser. No. Problems in reply to Rob Bush, 06-03-1998 12:38:53
: I just bought a wonderfull little WD at a farm auction. To check the year, I looked to find the ser. No. on the rear end. There is no number and looks like there never was one either. The number on the side of the block says 45-35490-G. It has no traction booster. Does that mean the moter is out of a WD-45? Is there any other place on the tractor to find the year? Is there such thing as a WD originally not having a ser. No. on the rear end. It has no "snap-coupler", so it has to be early.
: Thanks Alot For Any Responses,
: Rob Bush
Rob, I couldn't find the serial number on my WD either. Than I saw a posting on this board that said stand in back of your tractor and see where the shock from the seat bolts to the rear axle. Look at the same area on the other side. I had to scrape all the paint away but the number was there. Thanks to whoever had posted that because I had looked all over. DJ
Glen Gilbreath
06-27-1998 08:05:35
 Re: Re: WD Ser. No. Problems in reply to DJ, 06-04-1998 18:37:39
: : I just bought a wonderfull little WD at a farm auction. To check the year, I looked to find the ser. No. on the rear end. There is no number and looks like there never was one either. The number on the side of the block says 45-35490-G. It has no traction booster. Does that mean the moter is out of a WD-45? Is there any other place on the tractor to find the year? Is there such thing as a WD originally not having a ser. No. on the rear end. It has no "snap-coupler", so it has to be early.
: : Thanks Alot For Any Responses,
: : Rob Bush
: Rob, I couldn't find the serial number on my WD either. Than I saw a posting on this board that said stand in back of your tractor and see where the shock from the seat bolts to the rear axle. Look at the same area on the other side. I had to scrape all the paint away but the number was there. Thanks to whoever had posted that because I had looked all over. DJ
Another possiablity it the left axle, only place I could find anything that looked like a serial number, turns out to be a '49 WD on mine.
