Allis WC clutch change
TL in ny
04-04-2005 15:58:21
I am going to help a friend change the clutch in his '47 WC and service manual says pull the engine. I am not familiar with A-C's,I own Farmalls(M and 300) which required splitting the tractor.I would appreciate any suggestions or tips.
Texas Denny
04-04-2005 17:50:06
 Re: Allis WC clutch change in reply to TL in ny, 04-04-2005 15:58:21
I agree with all that WDTom says. I make a dummy shaft on a laythe that fits the pilot bushing and then the inside of the clutch disk spline. Getting this lined up right is very important. It's tough enough to get it together even when it is lined up. When you are pushing it together, you can line up the splines by putting the transmission in neutral and engaging the pto. Turn the pto and the pilot shaft will rotate until it slips in. May need two people - one to turn the pto and another to push back on the engine.
wdtom
04-04-2005 17:04:51
Take off the hood, radiator/cowling if it has cowling. Watch out for the bolts holding the radiator onto the frame, on my WD (basically same as a styled WC) if you use bolts that are too long you will punch a hole in the bottom of the radiator tank. You get to these, capscrews really, from under and inside the frame rails. You may need to take off the steering U joint for clearance. Move engine forward and front end up as it clears the transmission input shaft. It is tight, but will go. Have the clutch plate aligned before you go to put the engine in. Or leave the pressure platae loose enough so the clutch plate will move as it aligns itself as you are putting the engine in. If you do thes you tighten the pressure plate bolts by turning the engine over and little by little tightening the bolts brom the access cover on the back of the bell housing. It is easier if you can get or make a wood aligning tool. I have doneit by eye, but it doesn't work as good.
