WD45 Tractor
W. GRAY
04-04-2005 07:22:15
Have AC engine Serial# 45335432PA. Is it realy a WD45 block! Thanks Wayne
Ida Red
04-06-2005 18:37:08
 Re: WD45 Tractor in reply to W. GRAY, 04-04-2005 07:22:15
I Have a good Allis original trip bucket front end-loader for a WD45 for sale.Red
Texas Denny
04-04-2005 08:46:33
Wayne, I can't help you with that number. On the right side of the block, WD and WC engines had a cover that ran the length of the block to get at the lifters for the valves. The WD-45 does not have this cover. The block is smoth from the head to the pan. That tells you if the engine is a WD-45. Some WD's were sold with the WD-45 transmission. The WD-45 transmission has a curved shift lever. If you have the curved shift lever and no cover on the right engine side, your tractor is a WD-45 all the way.
WAYNE GRAY
04-04-2005 09:49:39
 Re: WD45 Tractor in reply to Texas Denny, 04-04-2005 08:46:33
THANKS!
Brian G. NY
04-04-2005 16:27:43
 Re: WD45 Tractor in reply to WAYNE GRAY, 04-04-2005 09:49:39
The number you listed doesn"t sound correct. A WD-45 Block would begin with 45 but there would be a - between 45 and the rest of the number. Secondly, the suffix on a WD-45 high compression gasoline engine would be "G" and thirdly, WD-45 block serial numbers only ran up to about 45-101415. The WD blocks were prefixed with WD and the numbers ran up to about 358500. The WD high compression gasoline engines were suffixed with "PA". So.....,if you replaced the the first 2 digits of your number with WD, your number would indicate a WD engine of about 1952 vintage. A steel plate on the side of the block is a dead giveaway that it is a WD engine.
W GRAY
04-05-2005 07:51:04
 Re: WD45 Tractor in reply to Brian G. NY, 04-04-2005 16:27:43
Thanks Again!!
