Is it possible to connect
Stoneynsc
04-03-2005 17:45:57
a B front end and motor to a C transmission and rear end? I bought what I thought was a B on an auction yesterday but when I got it home I noticed that the rear end was wider than my other B's. The front ends were identical though. Then, when I checked the serial number it was C12372. Anybody got any ideas?
Stoney
Rod (NH)
04-03-2005 18:19:41
 Re: Is it possible to connect in reply to Stoneynsc , 04-03-2005 17:45:57
Hi Stoney,
If you have the "wishbone" front axle and if the steering arm that attaches to the gearbox points down, not up, you have a B front attached to a C rear. I think they will bolt right up at the torque tube-to-transmission housing joint.
third party image Rod
Stoneynsc
04-03-2005 18:23:46
 Re: Is it possible to connect in reply to Rod (NH), 04-03-2005 18:19:41
Thanks
Texas Denny
04-03-2005 17:55:00
I believe the rear axels are about the only significant differences between a B & a C. CA engines will bolt up to either also.
Stoneynsc
04-03-2005 18:17:31
 Re: Is it possible to connect in reply to Texas Denny, 04-03-2005 17:55:00
Thanks. This tractor had been repainted and had a B decal on it. I guess I have a wide front end C. The steering linkage is down low going from the steering box to the front end like on a B, though. Maybe it's bastardized between the two.
Stoney
