magneto switch
Dan Butzer
04-03-2005 11:47:40
I have a 49 "B", it has a 6 volt system and a distributer. Do I still connect the mag wiring to the distributer, or what do I do to kill the engine?
Thanks, Dan
old
04-03-2005 12:02:52
 Re: magneto switch in reply to Dan Butzer, 04-03-2005 11:47:40
If you have a dist. you need to hook up a switch to go to the battery and to the coil. Mags are wired so the wire goes from the mag to ground to spot the tractor, and with a dist. system you have to have battery power going to the coil for it to work
