3-point lift problem
jiminoystercreek
03-31-2005 03:00:50
I have early 50's WD with a WD45 head setup. Have aproblem with the 3 -point lift. It's up all the time. When I try to lower it, it will go down about an inch, that's all. Anyone have any ideas on what to look for?
Scott-IA
03-31-2005 14:06:06
 Re: 3-point lift problem in reply to jiminoystercreek, 03-31-2005 03:00:50
My first guess would be that the linkage is set wrong. Re-set the hydrolic linkages per the owners manual. Proper setting makes a world of difference
Brett in KS
03-31-2005 12:00:45
Is your traction booster turned on all the way (I don't know if a WD have a traction booster) On my D-19, If the three point is down, and I turn on the traction booser all the way, the 3 point comes up. Just an idea.
Brett in KS
Texas Denny
03-31-2005 10:57:16
Jim, I can't help you but hope someone can. I have a John Deere MT with the exact same problem. At idle and with lots of effort, I can push it down, but it comes righ up again. I think it is a valve leak. Just haven't found the time to look at it yet.
