Model B 12 volt conversion wiring diagram
Emory Johnson
03-30-2005 19:50:20
Does anyone out there have a 12 volt conversion wiring diagram for a system with a magneto instead of a distributor? Your help would be greatly appreciated.
Keith-OR
03-31-2005 21:35:38
 Re: Model B 12 volt conversion wiring diagram in reply to Emory Johnson, 03-30-2005 19:50:20
here is a website that might help you...Keith
steve(ill)
03-31-2005 19:14:33
on a distributor system, the ignition switch puts 12 volts from the amp meter to the coil for a spark. open the circut and motor stops. --- on a mag, the igniton switch grounds the magnito wire to "stop" the motor. the wire is an open circuit when running.----- -- other than that. all the other wires are the same on the two tractors.
Rod (NH)
03-30-2005 20:12:24
Hi Emory,
Here's how I did mine. Perhaps you can get some ideas from it.
third party image Rod
