D17 Diesel
Kevin (FL)
03-30-2005 14:23:57
Anyone have any extra fuel lines for a D17? Our '59 has a brazed area on the #4 line and it has started to leak sometimes. Why it leaks sometimes and not other times, I can't explain...
BM
03-31-2005 19:48:51
 Re: D17 Diesel in reply to Kevin (FL), 03-30-2005 14:23:57
I sold all my lines, but have many good parts for sale off my D17 series II diesel. All injectors, lines, grille insert, and tach are gone. Just thought I would give you an option. Thanks, Bob (812) 847-7111
Don Dittmar
03-31-2005 04:38:39
I am glad to hear you are replacing them. Brazing/welding of fuel lines is not reccommended due to the fact that the braze/weld can leak through and partially clog the fuel line. As far as used, i cant help you. SOmethiing like that I would go straight to Allis for
Kevin (FL)
03-31-2005 05:45:32
 Re: D17 Diesel in reply to Don Dittmar, 03-31-2005 04:38:39
Thanks Don--I'll check with the dealer--he's over in Alabama, about an hour's drive. The #4 line was repaired that way when we bought the tractor. I didn't notice the repair until the other day when I saw the leak. Was surprised the brazed joint could even handle the high pressure.
JC(WI)
03-31-2005 22:20:22
 Re: D17 Diesel in reply to Kevin (FL), 03-31-2005 05:45:32
I brazed the line on my D17 back in 83 and still holding. When brazing, one has to figure how thin the line is or if cracked. If it has a big hole , forget it and get a new line.
